smokeme
Established member
I want to know what injection pumps were used on the 1910cc 8v turbo engines..
I have a mk2 punto with the 1.9d engine that has a lucas epic injection pump as stock.. I want to turbocharge this engine and use a mechanical pump for reliability..
i've been looking at the marea td100 pump but can't seem to find much info on the net about it..
eper says all the engines are diferent even though i can tell otherwise, same bore and stroke along with the same firing order.. only diference is the higher compression ratio on my engine since it's NA..
so in my thinking if i pull the pump and injectors from another engine and place it on mine it should be good to go.
Any ideias?
I will NOT keep the epic pump, it's widely known lucas pumps are not very reliable but the epic really leaves up to it's name.. the ford transit and pug 406 guys are all going back to bosch pumps since they have similiar engines fitted with them, i have no such luck..
Any ideias?
