Has any body fitted a -t- piece into there fuel line for feeding a diesel heater for a motorhome and would it be fitted before or after the fuel filter, fiat 2.3 multijet 2013/14
Hi just to add the low pressure fuel lines are hardened plastic so you would struggle to stop your t piece leaking the part listed by corcai looks perfect for the job
Put my details in will not fit to any of the ducato marks, I did recieve a unit to fit in the tank but was not to sure about fitting It, The thought of cutting a hole in the tank put me off, sorry for not respondin earlier, Thanks Bryan
If the tee piece was fitted before the fuel pump would this reduce the pressure, allso what colour pipe would I need to connect too the yellow or the green connection from the fuel tank. Thanks in advance this time, Bryan
