Diesel Engine Oil Usage
I
Insomnia
Out of curiosity, how often do you (as a owner) top the oil up in your diesel (whether it be TD75, TD100, or JTD)?
I check mine every month or so and it does seem to need a little top up. There's no oil on the drive so its not leaking unlike my previous 1.8.
IIRC my old diesel metro needed a fair bit of topping up over time so I'm wondering if its just a diesel thing?
My mileage is relatively high at 18000 miles a year.
Mar '99 1.9TD / 37,000 miles
Current Status: Running Well
I never fill up. Everytime I check its above the middle part of the stick I guess where it should be
I never fill up, always at max each time i check.
Made in Fiat
A guy at work as an S Reg, SDI Golf (Mk4).. 68BHP I think they are - That uses about 1½ litres every 10k.
Ins...
how "much" topping up are you doing? Just wondering as I have a TD100 that uses about a 1/3 to a 1/2 on the marking on the dipstick between 6k oil changes I do on it. So as others have mentioned its about a litre of oil every 10-12k. All depends how you drive it and where. If I am doing town driving or giving it some stick then it drinks that little but more
Greg
Mine also never needs topping up i do around 10,000 a year .
its the turbo on the td that eats the oil not the engine.
unless its needing oil every week you dont need to worry. its normal
I wouldn't say its guzzling it, just slightly using some.
Sometimes when I boot it (as much as you can in a TD :) ) I see a fine cloud come out the back. Few and far between mind you.
Essentially it had a full service 6k miles ago and no reported issues then so I'm not worried, just wondered if others had similar experiences.
hi,
I change my oil evey 6000 on my jtd and to be honest i very rarely need to top it up. maybe i should check it more often lol. i do lots of miles too about 18000 a year hence the jtd !
Kind regards,
its more than likely a slightly weepy internal oil seal on the turbo. if it were gone it would smoke loads on idle and drink oil. dont worry they are called oil burners for a reason :)
I
2
1K
Dark Lurker
S
2
640
Dark Lurker
C
2
787
Dark Lurker
900
David
M
2
759
Dark Lurker
