Technical Dials not working punto 16v hlx
tamworth
Hi.
I've got a fiat punto 16v HLX .
The issue is that the car runs normal with no issues. But the dials do not work. So NO revs, fuel gauge,temp gauge,speedo.
If you put indicators on there's no lights illuminated on clocks set.
The temp gauge warning light is always illuminated. Time and mileage is working.
I've swapped out the clocks into another car and they work fine. Revs etc.
Think I know the answer but want some advise just in case I'm wrong.
Thanks in advance.
I've cleaned wiring to back of clicks and pulled ecu wires off and contact cleaned them too.
Hi.
Thanks in advance.
If a Donor Clocks all worked correctly - and yours dont
that kinda yes tells you the answer your looking for
Sounds like a resistor/capacitor has shat itself and took the lot out
However - ENSURE your DONOR CLOCK HAS LESS MILEAGE THEN YOUR VEHICLE!!
ITS A MUST MUST MUST
You will then need todo a proxy alignment procedure (Availible via a decent auto sparky or a Paid Edition of Multi-Ecu-Scan)
This will stop the clock/mileage flashing and correct a lower mileage to your mileage
Ziggy
Sorry little [email protected] understanding....
The clocks from the car worked in another vehicle.
But not vice versa.
That email address hahahaha
In that case then - something on yours has Disappeared
If you have NOTHING on the dash at all, its going to be a power issue
A burnt out wire - blown fuse - duff BSI - Relay died - Dodgey ignition switch feed? - no earth return?
I need to find my haynes later on to see if i can find a reason for you
Ziggy
Ziggy[/QUOTE
There are lights that come on at start up. All I think then go out. Airbag stays on and so does power steering... dials twitch at first turn of key but that is it ... no idea where that email address came from lol...
