Technical  Diagnostic tools
Cliffh
Velddrif
If my fuel pump/fuel gauge on the dash is not showing me the correct amount of fuel on the fuel gauge, is there an electronic tester of sorts that one can use to determine what the problem is?
Pretty sure I read your original post.. re. Testing before swapping the pump
Check wiring..
If sound you COULD experiment by reading the values at the wiring joint..
MES will test power to the gauge.. but you already know its 'alive'.. just not accurate
