lean against it to make it click shut! or slide finger in... em hold on rephrase!! put ur hand in the gap pop n pul it quickly. xxx
you really make it too easy dont you!alainax said:or slide finger in... em hold on rephrase!! put ur hand in the gap pop n pul it quickly. xxx
The good thing about Computers, Chat Rooms, Text Messaging and other typed in communication tools are that if you think something you can take a couple minutes to rephrase it in your head and never actually have to type in on screen and let everyone know how filthy your mind is. Tis greeetalainax said:oh for fcuk sake!! n that was me changing what i was gonna say!! god damn!! xxx
alainax said:1. you must at all time have a spare fob.
2. never have the two fobs in the car at one time
3. if traveling it can be advised to keep the spare on you some where, ie not in a bag or jacket as these can be left in car but on your person.
4. if the fob is locked inside get the spare.
5. some people advise having a popper button somewhere on the vehicle for safety however this can leave the vehicle in danger of being easily broken into as thieves are aware of areas where buttons can be put no matter how ingenious you think your idea is.
6. never leave the car running or the keys in the ignition, as if the door gets closed by accident the spare fob will be unable to open it.
7. always go for the more expensive option of having both doors on poppers because if one fails you always have back up.
9. never leave both fobs with another driver if you are letting someone borrow your car or is in a garage etc as they will not be aware of the severity of closing the door.
8.be prepared that one day you may have to break your window
xxx
poggy said:I thought part of the MOT and vehicle construction regs was that you must be able to access the car via handles from the outside. If you take a car for a MOT and the door handles don't work, it will fail. Happened to my brother.
alainax said:thats what i meant about keep a fob on ya, ie belt. ( or thong)xxx
obviously not using the right linesHellcat said:Getting to your belt is normally easier than to your underwear...![]()
jenks69 said:Only if they are presant do they have to work. Same as lights - if you remove all the lights from your car and fill in the holes for them, remove the wiring and the controls, then they are not going to fail your mot! It's an odd world this MOT malarky - if its there it has to work, if it isn't it doesn't matter!
