General Dash top grille
andysat
Hi all my daughters 57 plate grande punto has the top dash grille popped up on one side -(the inside as dash meets screen)-looks like a tab has snapped for some reason-are they easy to replace or a pita?-thanks
There are absolutely loads of threads on the forum here, try searching something like "dash vent", it's a very common problem.
Usually just a broken clip at the right hand end. You pull the old one out all the way across, the cure is a new one - used to be reasonable price direct from Fiat as they did so many of them!
Think the part is 735411115.
Also read here someone managed to find the right glue I believe: https://www.fiatforum.com/grande-punto/288423-fixing-front-heater-vent-trim.html
Depends on whether the end fitting is there or broken. If broken I haven't come across anyone on the forum here who has had luck with glue (yet).
Also check ebay for the part they come up on there from time to time
