I've just bought a 2001 Punto with only 47,000 miles on the clock for £100! It had a lumpy idle, tried a few things such as cleaning injectors and change spark plugs but no better! Did a block test and went immediately green so whipped head off this morning hoping cylinder head gasket had gone! No
obvious signs of gasket failure but found something even worse!!!! No 1 cylinder has had debris flying around which has scored the bore and damaged piston crown to the point where there is a small hole! Account for the blue smoke on start up and lumpy idle!
My question is if I buy another engine and fit it will I get Engine Management Lights on galore? I know I bought this car cheap but spending £150 or so on another engine the budget is getting tight on whether the car is actually worth the time and expense?
Any suggestions on how much a headache changing engines over would be appreciated before I buy one?
Mark
Mark
