Panda Cutting out
Panda Cutting out
Lyndonma
Losing all power as if the ignition is being turned off. Have changed the crank sensor and ht leads one was arcing. No pattern to it can go days with no fault of 6 times in one day. Have checked the alt and batt wires seam to be ok.
Will check that just I think you would get a dead key sometimes which is not the case. Panda is a 05 plate been thinking about it could a earth fault, any thoughts
hi,
still on the original battery?, power steering dumping at the same time..??
our '04 did this last summer - before a new battery cured all ills,
Charlie
