OnyTheMessiah
Hey All!
I trawled through all the similar threads before posting this, but I probably missed something.
My 1.9 JTD cut out at lights after a 15 minute run. It restarted after around 10 minutes and ran happily for 10 minutes then I parked, shopped, restarted it fine and ran happily for the 20 minutes that it took to return home and park.
I thought nothing of this.
After the weekend I drove for an hour and a half in various road conditions on a hot day covering a distance of around 75 miles, parked the car for about half an hour and then headed for home.
After 10 minutes it cut out. Again it would restart after time, happily rev and hold at various rpm, but after going into gear it would swiftly cut out with the engine management light on.
We got recovered and the mechanics could find no mechanical problem, but experienced the same difficulty.
On returning home we sent it to the garage which is literally round the corner, but not our ideal choice. They called in their diagnostic guy and we got a call back to say we needed Glow Plugs and at a considerable price...I had been looking through here in the meantime...On picking up the car (work not done) the mechanic explained to me why it was the Glow Plugs and mentioned that the diagnostic had suggested that the Crank Shaft Sensor threw up a problem, but when checked "the numbers were within the correct range." at which point I reported the findings on here about Crank Sensor issues. The mechanic looked disappointed and puzzled before telling me that the diagnostic guy knew that there was a problem with the Glow Plugs and so it would be best to start there. He agreed that there was no need for Glow Plugs to function but said that they may cause the engine management to cut out the engine.
I am inclined to ignore him and follow the advice on here, take it to another garage, ask them to fit a new Crank Sensor and see how it goes. I ought to add that we kept getting Oil Warnings about a month ago and the garage to which I intend to take the car to again could find no fault and "fixed" the problem by fitting a new sensor.
Sorry this is long winded, I have tried to include all the information that I have.
Should I pay out the fortune that the local garage want and probably end up having to then pay for the Sensor to be replaced later as well OR trust my instincts and get the Crank Sensor changed? Is there something I have missed?
Thank you!
Thank you!
