General Custom units changing
Surrey
Hello all,
I’ve had a 21 reg TIPO cross since August. Four times now, the display has reset the fuel range and total odometer reading from miles to km on its own. It’s always when I’ve parked in the same area of the waitrose car park in Sunningdale which is next to the station. Switch off the ignition showing miles, and when started again it’s in km.
I think it must be an electrical issue from the level crossing signals but I’d welcome thoughts.
Do the gates use radar to detect vehicles that’s a possibility we had a problem with early central locking where they were picking up ham radio transmitters.
I’ve no idea. I just know it’s only when parking here on a Saturday morning that the display changes.its not done it anywhere else.
That line is 3rd rail electric and there will be a chance of flash over when the trains
start from the Station or cross the road as it will have gaps in the power rail there,
though I have never come across it changing the instruments, you never know,
if it was doing it in other places I would suspect the car battery or ignition switch.
can you hear and odd noises on the car radio when parked there.
The dab occasionally looses signal at the crossing but that’s about it. Curious isn’t it!
I used to get the same on my 500X. Did it a few times. Sometimes my actual mileage would change from miles to Km.Other times mpg to km.I never worked out why it did it. Never had the problem after having a new battery fitted under warranty at 13 months. Battery had a dead cell so wether it was something to do with it or just a typical Italian electrical issue not sure?
