Curious problem with headlamp switch
S
spacecowboy
Hi, my Brava 1.4 headlamps are not working properly, the sidelamps and full-beam come on fine but just normal lights comes on very dim. If I push the headlamp arm forward a bit the headlamps come on normal but I have to hold it there which is a bit of a nightmare in London traffic. Also I think the bulb behind the odometer has expired because that no longer works either.
Does anybody know what the problem is? I'm hoping the problem is just with the switch itself.
Thanks in advance.
SC
With regards to the odometer its just a bulb, theres a walkthrough on the Bravo Guide to fix it.
I would suspect the headlight problem is the stalks, there was a spate of problems on here a while back, a quick trip to the scrappy should sort you out.
Darren
Cheers guys - off to the scrappy i go!
Found out that the headlight stalk new cost £68 from Fiat main dealer blimey!
C
7K
ChrisKnottIns
C
W
927
wakka
W
T
1
811
Joseph
J
1
764
Ozric-Al
O
