BoardinBob
I posted this in the Doblo forum but thought I'd fire it up here too as it is more of a cross model compatibility questions
I did two trips down to the French alps from Scotland last year and having previously done the same journey in a big Volvo with cruise control, I'm looking to put cruise control in my Doblo. It's 1,300+ miles on motorway each way in France alone and the cruise control makes it a much more pleasant journey.
I got a quote from a local auto electrician of £600 to supply and fit which is quite eye watering.
I can see aftermarket kits online from £200
http://www.ncs-systems.com/car-elect...iat-doblo.html
And some more expensive options up to about £400.
However having done some reading on here and elsewhere, I was wondering if the Alfa 147 stalk would fit? I'm guessing this hinges on whether or not you have have the socket already installed under the steering wheel. All the aftermarket kits state it's a CANBUS system so I assume it's plug and play without too much wiring to be done.
Various posts on this forum about people fitting the Alfa 147 stalk to a different Fiats and it works perfectly.
https://www.fiatforum.com/bravo/16966...o-sport-3.html
My Doblo is a 2012 1.3SX turbo diesel. Is it simply a case of popping the steering shroud and if the cruise terminal is there I can use the Alfa stalk?
