General crap heater on my stilo jtd, how do i fix it
wales, carmarthen
:slayer:just bought this car and i did have fiat bravo before it and now got this car instead.
the heaters are propa crap and in my bravo they were propa really good.
there is heat coming out of them and its war but the blower is terrible. there is hardly any heat coming out of the feet department.
anyone know how to solve the problem then please let me know as the snow is coming in really bad here and i need really good heaters.
even though i got the air con, i dont want to use it as it uses alot of diesel lol haha.
HELP
:slayer:
well i have just :slayer:done what it said on the post and its not the same on my car. i got air con on mine. dunno how that changes things but i pulled both pannels off the driver side and passenger and there was just a tube thing each side and i couldnt pull them out or anything.
so can i have some propa help please.
yer i am looking at the rite guide and it doesnt look like that on my car. not even on the driver side or the passenger side. so i dont know wat to do coz the feet heaters are propa terrible and i need a propa guide on how to fix the problem:slayer:
remove the centre console right hand side panel and look propa:)
:slayer:rite to start with my car is a 04 plate and a 1.9jtd.
all these diagrams do not look like mine, i have pulled everythin off on the passenger side and there is just loads of wires and the tube bit where the air come out of. there is no little plastic clips that u pull back to get the pollen filter out or anything like that.
i dont have a clue, just need someone to help me get at it so i can fix the problem:slayer:
so were abouts is this thing then???
do i have to pull the plastic bit off arount the gear stick uswell or only the plastic sover thing in the passenger foot well.
the pannel that has like a blastic screw thing holding it inn. once you pull that off then you can see the heater console and a metal bar but not the pollen filter
this, but on the DRIVERS SIDE!
after you take the panel off, look right at the back and there should be a plastic flap/lid with a screw in the middle. its right by the steering column. its not that obvious so look hard. you'll need to be upside down for this
are you winding me up? :p
i've written DRIVERS SIDE in capitals 3 times now. also where else will you find your steering column!? :rolleyes:
on the driver side or the passenger side????
Looks plain enough to me.
:slayer::slayer:eek:k i found the thing, in the ends uswell. cheers for all your help.
just wondering on how long the thing is as i pulled it out and it was quite small. and it has made abit of a difference but id there any other way to make the heaters work better.
:slayer:
(y)
How r ya,I have the the same problem with my Stilo.All the hot air goes to the screen and non to the feet. i've gone the polen filter route and its still the same. try messing with the hidden menu's in the climate control press the rear heated screen button for 5 secs after start up to access them. i keep mine set to 23 degrees and its to bad.
