Peterg said:
Dunc
Was it easy to replace the screen as i have to replace mine and prefer to get one from a scrappy.
Pete
I can answer this one for you Pete.
Yes, it is easy to change the screen. Lubricate round the rubber seal (WD40, silicone grease etc.), and pull it away from the edge of the windscreen aperature to break the seal from inside the car. Now gently but firmly using a constant pressure, push the windscreen out starting at one corner. Try and use a flat, soft surface like the soles of trainers to push and spread the load. You should find the windscreen will start to push out along with its seal. Work along the edge until the screen and seal is almost out at the top edge, then you should be able to pull it away from outside of the car.
Never push from the centre of the screen as you'll almost certainly crack it!
Refitting, you get a piece of strong cord that will wrap round the whole of the windscreen seal sitting in the channel. Using rubber grease or silicone lubricant again, smear some in the rubber seal. Now place the screen with seal into the windscreen aperature, but try and get the seal to sit along the lower flange.
With an assistant applying
gentle pressure from the outside, pull the cord at a right angle to the screen from within the car. The rubber seal should pull over the windscreen aperature flange as you pull it along the edges of the screen.
You might need to fettle the screen from the outside as you fit it, to make sure it locates properly. But other than that it is a fairly simple job, though do bear in mind there is always a risk that a screen can crack when fitting.
The last thing I would add is that there is more chance of cracking if the weather/ glass is cold, and also the rubber is much more pliable when warm. Right now is not a good time to change a windscreen as the weather is too cold! If you have to change the screen now, then try and do it in a heated garage after leaving the car in it for a few hours to warm up.
Best of luck!
Chas
