puntodad19
- Joined
- May 1, 2019
- Messages
- 188
- Points
- 104
I am hoping someone can post, or direct me to a correct wiring diagram for the lads Punto Evo...
Punto Evo active 2010 1.2 8 Valve....
Any more info needed to select the correct wiring diagram ?
Area of interest are fuse box locations, fuse numbers for various circuits, relay locations and functions relating to headlight, please.
The headlights refuse to stay on, dip works ok as does high beam flash...but high beam refuses to stay on !
All other light functions seem to work ok, it's just high beam will not stay on when selected.
I suspect the steering column combo switch is playing up, but it's steering wheel off etc. to change the switch.
We have yet to remove the switch plastic covers to see the switch better ( at all really ) , and possibly clean and luv etc ..
Thist things first, fuse and relay locations, and a correct wiring diagram...
Thanks in advance...
