Connection loose!!!!!!!!!!!!!! help!
K
kami
My car bilnking and other lights got a problem. Sometimes work sometimes not. They said to me because of the Earth connection loose. Anybody knows where it is for my Brava 1.6x 1997 Modell in order to fix it myself. Thanks!
Kami
Re: Re: Connection loose!!!!!!!!!!!!!! help!
The obvious ones would be from the negative terminal of your battery, i presume the one from the wiring loom links em all but can't find in the haynes manual where exactley it is
If it's the problem of your interior centre console lights coming on with indicators or brake lights it's the negative in the rear light cluster you need to sort out.
If you pull the back off the light under the cover (as if you're replacing a bulb), it's on the block connector there.
Sorry if this is about something different.
Ollie
Re: Re: Re: Connection loose!!!!!!!!!!!!!! help!
Thanks! It sounds correct but I did not get where it is exactly. But when I use indicatores then the rear light and break lights also start to blink!
Kami
Re: Re: Re: Re: Connection loose!!!!!!!!!!!!!! help!
that happened to me, its what ollie said the wires in the block connector are loose.
i just fiddled and pushed them in and its been fine since.
3
1K
Tommy K
T
S
1
275
Stephen
S
B
2
561
Sabre 23
S
