Technical  Computer gives high temperature
creusen
I have motor home on a Fiat Ducato chassis.
I have an issue with the computer. The computer indicates that the temperature is too high, however the temperature gadge give a constant water (coolant) temperature and sits in the middle of the gadge.
I do not believe the software (computer) an rely on the mechanical gadge. However when the computer indicates that the temperature is too high the speed controle shuts off and can only be set again after the engine has been turned off and on again.
Am I the only one with this issue??
Via a other forum I got the tip to check the cooling circuit and have it bled. The problem has not returned ye so it looks like their was air in de cicuit.
