Technical  Computer connecters not labeled
LeadMagnet
So I bought the full wiring, techincal drawings and troubleshooting guide for my Fiat Doblo 2002 1.9 JTD.
I'm planning on installing a after market remote central locking device.
In the manual, it tells me....
"The body computer M01 controls the cental locking system motors, from pins 16 and 18 of connector D in the junction unit under the dashboard B02 via the short circuit coupling D97"
Great, so i know where to attach the unit. So pull the computer and there are 8 connecters (5 on the front, 3 in the back), NONE OF THEM LABELED! :bang:
If torn the manual apart trying to mind anything that shows labeling and come up blank.
Here's a picture of the front
And the back
Does anyone have any idea which connectors are which?
Please use the forum's attachment system for adding pictures as our file host is blocked by the network at my work so can't see them.
Does the manual not help at all, ie a diagram labelling each connector and showing how many pins it has so you can at least try and narrow it down?
Sorry about the attachments, I've embedded them this time.
FRONT
y4mpivj0La2flW1XRqKSc82PUw1lTR8f6Xf9fv2NkYorH07gXdYdDYjdw5xILnnERnlbSTj9Fqtp-IdEMtdySi7x3v5zK1swVNx0mEcZJLn5Mj7xd92YUqgL-yccf6KtxOEuhlfbsithJOekPIiZERKcA8ze7RYxOsvpZUI9GJf2gb9M46nUJk54S0cZSMZZdg_AP0VKVOeKpKBEAsArtXkFg
BACK
y4m5s5ujANrMahAktsMzrNkmhcVFVKnmpfcZ8wtAqgStUAp--6O6eVpP4EWHNa1YDs7IWH-DlRjITx8JD6dSOASfh6dy97IvcpAwN2FwQ-jlJbU6rqKiebwLRo9gj6hqVlKRY1E75RRgZjyFJG4g9qkoXcwSFph0eyD2ABcuM6y5gkStWy4TSganpvAqQHG8nutspTf-0kzIsUmfB-zM3XYOw
The manual shows the computer but the drawing is not a spot on identical representation of the unit. Several of the connectors have the same number of pins. The only thing different is the connector shell cover color is different.
The only connector I've been able to 100% identify is the main power bus from the battery, as it only has 2 pins and there is only one of that type.
Very frustrating.
