Component speakers. !!!
T
Tim
hello all..
hope everyone is well.
ok.
so iv had some front door speaker adaptors for about 3years now and havent done anything with them. iv got a little cash so figured id do sumthing about it. i fancy a pair of INFINITY REFERENCE 5010cs componants which iv seen on ebay. but having read through shed loads of old posts on here about how to fit them im getting a little scared as electronics and wiring is not my thing. do u think its gona be more hassle than its worth for me.? should i just spend £40 on a decent coaxial pair?
what are your thoughts.?
if anyone has a good user guide writen out for fitting components to a bravo then id be very happy to read it. :0)
i dont wana do anything fancy. running from an aftermarket head unit and using orginal wiring is all fine with me. :0)
any help would be great.
thanks everyone.
Tim
Component speakers
get some coaxial speakers the same size as the existing ones, 5x7 i think theyl do the trick.
to be honest its as simple as you casn get, with the infinity referance you have the cross overs to yur tweeters, in the crossovers you just use the standard speaker input to the cross over then out to the components then to the tweeters. plus to plus minus to minus its realy realy simple. id personaly recomend getting components ans tweeters rather than coaxials.
Definatly agree with Rascal dont bother with 5x7 coaxial speakers get some component speakers like you mentioned and mount the crossover at the top of the door and wire them down to the bottom really easy.
Yep its very easy,there isent anything that will stump you,even if you have never done it before,i just done mine and put the tweeter at the top of the door right in the corner.
250Watt Alpine joby's what a diffrence they make.
You will manage it no probs,if you do get stuck just post up here and you will get the info you need.
Cheers Scotty.
M
1
339
A
C
2
537
A
M
1
531
S
A
7
409
Sean Round
S
