Technical  Combo alternator
Mr Posh
Alternator has packed up on Combo took it off but I’m struggling to find 70 Amp replacement loads of 120amp
Anyone any ideas where I could get one
Cheers
Also is there any way to remove it without taking driveshaft out it won’t come out the top ?
Has anyone taken drivers side drive shaft out I can’t find any info about how to remove them
Going to try remove engine mount support engine move engine slightly then hopefully be enough room to get it out
I am assuming yours is the 1.3 Vauxhall Combo version of the Doblo.
I did a gearbox change on a 2014 one a few months ago, this photo shows the drive shaft mounting points if any help.
I think you are right about supporting and lowering the engine at that o/s mount and largely working through the wheel arch.
Yep thanks for that that’s what I did bit moving about but it out
It’s seized cracks around the casing 😩
