General  cold air
General  cold air
needspeed
plymouth
hi, my sei only blows out cold air.the system is bleed and the radiator fan comes on and off as normal.
the heater dial has some resistance to it when turned to hot,it springs back acouple of notches to cold.could this be the prolem if so how do i remove the dash panel to access the dial's .cheers:)
To take the heater control panel off : -
Couple of screws either side, one hidden.
The hidden one is located behind the central knob of the three knobs. Will come out easily enough, Will slot straight back in also :)
Panel should come away then
hi ,had alook behind heater control panel and the hot/cold cable is not sliding through it's sleeve when the dial is turned,it's just kinking.
does anyone know where this cable goes,so i can see if theres a problem at the other end.cheers:)
