John H
Established member
I'm about at my wits end with this one at the moment, perhaps I'll get the better of it when I catch up on my sleep again (won't be on the bamboo spikes though
Anyway, here are the symptoms:
Sometimes cuts out at tick-over when fully warmed up, but not hot enough for the fan to operate. (usually at a set of lights with lots of traffic behind [xx(]
Generally a third to half of the way down a tank from full. ( the filler cap isn't totally plugging the tank )
Will restart after cranking for anything between 10 and 30 seconds.
There is no spark when it won't fire up, and I've seem the spark return under cranking on the one occasion it died when I got home and had time to put a spare plug in one of the leads before it started working again.
I suppose the fuel level might be a red herring, and the coil might be getting too hot and failing.. but it's a nasty little thing with a custom molded 4 pin connector on it.
When I have the opportunity to play again, without being in the middle of three lanes of traffic into Bristol street in a thunder storm (tonight) with irate taxi driver up my exhaust pipe, I'll see if I can check the coil.
It may be the Hall effect device in the distributor.
If it would stay broken I could (probably) sort it out.
The other more worrying possibilty is the ECU shutting the show down because of a problem I'm not aware of.
Oh, for a set of points !
