H hatter67 Guest Nov 14, 2004 #1 crunches into gear in reverse,, try 1st gear clutch pedal stiff slow taking off in all gears is the clutch going???
A Anonymous Guest Nov 14, 2004 #2 I was always told, if you stick it in 4th at about 10mph, then floor it, you can easily tell if its the clutch... If the car judders a bit and slowly speeds up, it is fine. If the revs go up, but you don't accelerate, your clutch has just about had it... Daz
M Mark W Guest Nov 16, 2004 #3 I drove to the bank,a 5min drive, left the engine running and when i got back in i couldnt depress the clutch at all. Then suddenly it went down all the way and sounded like a fkn bull elephant was under the bonnet.. thats how my clutch went No warning what so ever
G Gspot Guest Nov 17, 2004 #6 clutch had a new clutch 2 weeks ago £160 including fitting, my bearing had gone!
M Mark W Guest Nov 17, 2004 #7 without getting my receipt for the clutch, i honeslty cant remember. problem is my car is in the garage getting its gearbox reconditioned......
A AlfaNige Guest Nov 17, 2004 #8 ...unless you are a woman and have forgotton to depress the lickle peddle on the left, by your handbag
