Dear Forum, my Bravo 1.8 HLX (2000) had been making a whining noise for 2-3 months at the start of the year when I pressed the clutch pedal. In Feb I got the brake warning light and not knowing it was related to the clutch thought that my brake pads needed replacing. The noise got worse last week and on Friday as I pulled in to our drive the clutch pedal just wouldn't go down. I had a look under the bonnet and found that the slave cylinder seal had split (and looked like it had been for a while). I replaced the slave cylinder over the weekend, bled it etc. but that hasn't fixed the problem. I still can't push the clutch pedal down, there doesn't seem to be any feedback from the arm that the slave cylinder rod goes into (is that arm meant to push the rod, it's just loose at the moment). Car is in great condition for it's age and only done 78K. I'm not sure what to do next - any advice?
