Hello Community,
i have a very big problem with the clutch.
Initial situation:
- Clutch separated badly but it separated but only on the last milimeters of the pedal way
- Pedal feel soft and spongy
So I swapped the clutch...
I replaced the clutch disc, pressure plate, release bearing and slave cylinder.
After the change, the clutch is now even softer and the clutch no longer separates as soon as the engine is running.
When the engine is off I can shift into all gears with no problem.
Of course I've bled the system several times with 1.5 bar pressure on the brake fluid reservoir.
Only liquid comes out and no air.
I installed the clutch disc with the inscription Gearbox Side on the gearbox side.
In other words, the flat side of the clutch disc faces the engine.
I centered the clutch with a 3d Printed centertool designed for this engine.
What I also find strange is that the old clutch disc wasn't so worn out that it would have explained the problems.
Some pictures:
New clutch - "gearbox side" facing the gearbox.
Old release bearing:
New release bearing:
Yes - the new release bearing snapped / clicked in so it holds on the release lever.
Here two videos:
First Video:
Gear engaged - clutch not actuated.
Second Video:
Gear engaged - clutch engaged.
Looks ok, or?
But the problem still exists although everything looks ok.
When the engine is on I just can't put it into gear - of course I can by force, but if you try to put it in gear normally with the clutch pressed, it sounds like the clutch hasn't been pressed.
The master cylinder in the footwell is dry. Likewise, brake fluid shoots out of the vent from the slave cylinder when pressure is built up via the clutch pedal and the vent valve is opened.
So I'm ruling out the master cylinder.
Here is a video of the slave cylinder. What do you say, does the path covered by the cylinder fit or should the cylinder move out much further?
I hope you can accompany me on the way to solving the problem.
This is my first clutch that I've changed in my life and then immediately such a problem.
Fiat Punto 199 - 2010 - 1.2L Engine - 69Hp.
Have a nice day & thanks for reading,
Michael
Initial situation:
Some pictures:
Here two videos:
First Video:
Second Video:
Looks ok, or?
Michael
