Technical  clutch pedal
keo the dog
Hi all got a problem with lots of freeplay and pedal sits high clutch seems to be ok just pedal does not seem right it seems to bounce back on the freeplay when you release the pedal, no slipping or odd noises all seems fine but pedal feels odd with the excessive freeplay and sitting high
It's a 1.9 diesel non turbo doblo cargo
Appreciate any help or advice.
Next problem heater is crap ie slightly warmer than cold but definitely not as hot as it should be .
Next glowplugs don't seem to work have a receipt from last year saying all were replaced including control module any advice on testing would be much appreciated as I don't want to bypass with a button to energise unless I have to....Tia .
None of the issues showed up when I bought it the weather was good and it had obviously been started as it will start all day nicely just takes a bit longer when left overnight obviously with the weather being nice the heater was not checked...there is heat just not very much, and the clutch pedal was not an issue when I bought it, it is a recent development..... but hey thanks for the response
Hi
Check the clutch pedal spring is OK i.e. broken or come off.
I also had a issue with my clutch [fiorino] as it was only operational near the bottom of it's travel, and although it did not slip it was the pressure plate that was at fault on inspection the clutch linings themselves was like new!
The heater issue may be that the divertor flap not opening correctly, i believe your one is cable operated.
glow plug circuit is fuse protected....check this fuse, but a volt meter on each glow plug and check for voltage
LUIGI
Many thanks I will have a look will be in a week or so as off for a break to Spain in the morning. Thanks for taking the time to respond.... I will update when I find anything
