The bracket that operates the stop start switch has broken from its weld causing the amber triangle to illuminate. 2012 Panda Twinair.
To remove the clutch pedal do I have to remove the whole pedal box or can I remove just the clutch pedal in situ?
Is there any thing I should know before I attempt this job tomorrow? A pedal is £129 and 2 weeks to arrive so I’m going to weld it. It’ll probably be stronger than a new pedal.
If I disconnect the battery will it reset the fault codes or will it need plugging into a diagnostic laptop to clear them? Any help is appreciated.
