Hello to all,
I am still trying to resolve the clutch judder / chatter which my car seems to suffer from. Although it has improved since I last changed the clutch, its still there so I have taken the engine out once more to investigate and my suspicions are that an oversized Pilot bearing may be the cause.
To me there is far too much slack on the pilot bearing and input shaft. Both items are new but it's possible the internal dimensions of the bearing are too large. My measurements of the input shaft is a diameter of 12 mm but this will be measured using Vernier calliper a not a micrometer.
I have attached a video showing the play on the input shaft bearing and would be grateful for anyone's thoughts?
If this is not the cause of the clutch judder then I plan to inspect the rear suspension for worn bushes as I can't think what else can be the cause.
All help and suggestions appreciated.
Peter
Peter
