Technical Clutch bite changes?
Quite south.
So my clutch bites kinda mid pedal ish however like 1 in 50 times say I'll get in the car set off, lift the clutch and it bites very hard much lower than usual making the car launch forward rather more aggressively than planned (n)
It doesn't happen often at all and when it does it usually only does it once or twice and then goes back to normal. :confused::confused::confused:
hmm strange, maybe the clutch thrust bearing is not sitting right some times.. it maybe sticking.
Talon went through a phase of doing that when i first started driving him (after replacing the clutch and bearing) but it did free up over time.. maybe yours will?
i know with talon if you get the clutch just right you can make him judder quite bad... but i am sure that is more how i drive him. i really should take him higher up in the rev ranges, but i just dont like doing it.
