Technical  Clutch and brake pedal part number Abarth 500
RobertDynamo
Poland
What is the part number of the clutch pedal and brake pedal (full set - something similar to shown in the image) using the 55232828 clutch master cylinder pump?
1.4 T-JET, after 2011. I need it swapped because my clutch pump in 2008 Abarth died and no spare parts are available so need to swap the brake&clutch pedals to fit available clutch master cylinders...
the only requirement is to be Abarth (metal pedals) and fit with 55232828 clutch master cylinder pump
Doesn't look like :( Hahaha, FIAT.
On the bottom of the forum banner you've got the ePER link. It's the FIAT spare parts catalogue.
Search window is top left of the screen
If you look here:
on the 1st and 3rd diagram you've got in total 28 rudder bars (that's how FIAT calls it). They vary depending on the engine and options. You have to move the mouse over the circled 'I' on the list on the right side to see the options.
I'd suggest you try searching with the VIN number, it will then display only the corresponding parts, that fit your car.
One more thing: the link is for the MY2012 model. Because there's no post 2011.
