Panda Clock
Panda Clock
tattyhead
:mad::confused:Hello anyone know how to fix the clock on a fiat panda dynamic 2006 after it is set turn off the engine when you go to start again the clock time does not stay set.
Tattyhead
Most likely one of two things
1) battery is on its way out. Clock will reset due to voltage drop when cranking
2) high resistance in starter motor or (not as common) earth strap, voltage will drop while cranking
We were having this discussion last week at work for the same reasons, used to be a common thing when we saw more of the early pandas. Had one in for work which did the same thing, battery checked out fine and owner said it didn't bother them so we didn't chase it any further
Tattyhead
Hi, and welcome, :)
yes..almost certainly the battery..certainly a power drop:eek:
:idea: does the trip mileage also zero;)
Charlie - Oxford
Hi thanks for the reply the Battery is ok had it checked it looks like one of those things you need to ignore just the curiosity that made me ask thought there might be a way you can store it after setting the clock.
Tattyhead
Tattyhead
do keep an eye on the trip..if it's resetting too.
the the fault is not "clock-related";)
Hi have not noticed if the trip is resetting will have a look this is not my car it is my daughters first car she is working on the cruise liners at the mo so checking things out.
I did notice the passenger side front window does not open fully goes about three quarters of the way down is that normal.
Thanks for the reply
Tattyhead
Tattyhead
front should go down completely..but the left and right front MAY move in unison..or 1 in "steps"..:confused: can't remeber,
REARS probably go 2/3 down due to shape of door ( over wheelarch)
they are good cars..but reliant on a good battery/ charging system;)
Re: Window
Hi fixed the window there was a polystyrene block stopping it going down don't know what the block is for think i put back where it belongs probably an anti rattle device who knows anyway windows working thanks for your help.
Tattyhead :
No the car is in constant use we use it just for short journeys to make sure the battery keeps it charge.Anyway will keep an eye on it.
tattyhead
