Technical Clips needed for scuttle-2011 Ducato
Cochyn1
Corwen
Hi. Anyone know where i can source the clips in the attached photo please? Water getting through onto engine due to rubbish seal and most clips broken. Going to try and seal it using 10mm double sided tape and some strong sealant. Is this the best way? Cheers. Daf
eBay. Just identify the right ones as will be generic not Fiat.
Not sure, does your rubber seal have rectangular slots so the clip can go in and turn 90 degrees to hold in place, if so maybe.
Can you get one out intact , I use a tool for removing door trim etc. but you have to get it in the right place to avoid breaking clips.
Majority were broken and others damaged. This is the most intact i have👍🏼
If you give the exact model details or look on the down load data someone may give a better idea or even a part number.
I did have a quick look on my 2010 Scudo but getting bit cold and dark to mess around.;)
No worries! Mines a 2011 2.3 130bhp👍🏼
