General clips for securing CV boots
arc
this is where i stand
Manchester
When putting the driveshafts back in, i used a funny looking wire cable tie to secure the inner CV boot to the driveshaft. It's come loose, and covered the place in CV grease. The cat has a liberal coating too, which smells ineteresting when i stop!
Anyhoo, I think i got the clip out of a universal cv kit. I want a new one, but can't seem to find a suitable clip anywhere. All i have are plastic cable ties and jubliee clips (not good for keeping the shaft balanced!).
What are the clips called that i should be using, i had a quick look in 'frauds but didnt see anything. Was in a rush though.
Use the plastic cable ties, as long as they're the ones about 5mm wide and not 3mm wide they'll do the job lovely and are a lot easier to fit than the metal clips.
trying to secure my cv boots todays, whats the best method to use. ive got these metal clips that u pull around but they keep slipping.
ive read the post about using cable ties but am not convinced. been told that (nylon clips is it?) are now an mot failure so cant see how cable ties would pass an mot
any help would be much appreciated (y)
Luke1985 said:
You can get them on with some stubby nose pliers, but are a real pain in the arse to do :bang:
Why struggle and risk damage when the correct tool is available :rolleyes:
But you must have bought the parts, most good auto-shops selll them as well as the specialist tool suppliers.
