Technical  Climatronik Problem- Fiat bravo
Angel Bratanov
Hello i have a problem with the climate system system. Cold air comes out of one side and the other warm.What should i do?
Hello !
I have the same problem with my Fiat Bravo II.
During the winter, when the hot air is turned on, the left side emits cold air and the right side emits warm air.
I don't know what can make this problem and if it is fixed, you have solved it as a problem or can you help me with any information.
Thank you
I solved the dreaded flap issue on my bravo, got the parts kit from my local fiat dealer for £30, only took three days to remove all the trim and get to the broken parts.
