Is the 'clicking' coming from the drivers side front wheel?
Mine did this and on inspection it was the metal disc/plate behind the brake disc fouling when turning left (started as a click but over time built up to nasty sounding metal on metal grinding). Easily solved, take wheel off and the disc/plate can be bent away from the brake disc.
Could be the drive shafts, When the joints are worn they will click when they have slop in them. Grab hold of them and twist them and see how much movement there is in them.
cheers dogspods jacked it up today and took the front wheels off, it was the guard you described rubbing on the disk. just levered it out of the way spot on.
