Technical cinquecento RPM signal?
dac69er
Established member
suffolk
looking into an aftermarket ecu for my cinq as a little project.
most of it makes sense so far, apart from 1 item i am struggling to understand!!
the RPM signal wire from the ECU; from what i have read it is pin 23, yet all wiring diagrams i can find show pin 23 as being a coil wire on the fuel pump relay?
could someone please enlighten me on this please? thanks
I really wanted to confirm the wiring diagrams I have as I have seen the info you are on about, but in the haynes manual and other wiring diagrams I have seen, the wire from pin 23 goes to the coil of the fuel pump relay?
Before I look at ripping the wiring out for an aftermarket ecu I wanted to find a decent wiring diagram that actually makes some sense!
I changed the "simple" panel to the panel from the "sport-version" which have a RPM-meter. I only has to connect the pin23 to RPM-meter and it was ok like that.
As i understand, the pin23 signal is the ac-voltage with the frequency of RPM. It need to be so for security reasons - the ac-relay for, for example, fuel pump will stop it when the engine is stoped.
done a bit of reading up on it. makes sense now. learn something new every day. didnt realise such a thing existed, but makes sense why it is used. the wiring diagrams dont make it obvious.
thanks
