Tuning Cinq cam shaft
Josmx507
Hi
Been looking at some cams for the cinq and I see people use a punto cam. Which one do people use and does it make much difference?
Hi
Search 866 cam and you'll find info on it, its from a punto 75 but getting hard to find now.
nath
Is the timing the same and do you use the cinquecento cam pulley/gear?
Hi
You can use the existing pulley and the timing is the same but you will need some shims to set the valve clearances, it took me ages to get the correct shims. It does make a noticeable difference though.
nath
