General cinq 1108cc cam and 1242 cam
hi, rang a place up today they have a mondeo 2.0l fuel pump he ses that they are the same as the RS2000 pump does any1 no if thats true or not? placed the champion EON1 plugs back in the car and swapped the leads and MAP sensor to see if the car runs better like that let you all no if it sorts out the hesitation! :)
Not sure. Check the catalogue?
decided to just take tho one out of my N/A cinq and take it with me to match it up,,,,dont no why i didnt think about that before :)
car still hesitating its alot better now the cooler plugs are in and the MAP sensor of the other car seems to do the job better but there is still some hesitaton,fueling check is next!!
But that'll only tell you if it'll fit, not the kind of flow you should get from it. To my mind a V6 Granada, a Coupe Turbo or an RS2000 will want more fuel than a 2 litre Mundano.
I think somewhere in one of Ayrton (sorry, Aaron's) threads is the fuel rate.
They're not that expensive new from your local factor.
yes thats true,,,have to look into that then. i surpose i wouldnt mind buying a new one,and the regulator at the same time.
