These bolts don't "wobble" - all it is, the round "cup" part of the bolt, that pressesagainst the wheel's bolt hole when you tighten them up, is not fixed.. it's loose (like using a curved washer) so that it seats into the wheel bolt hole recess properly but still allows the shank of the bolt to fit into the 98mm PCD holes.
personally i'd steer clear of wobbly bolts..
Yes you can. But you must use wobbly bolts.
