RuiG
Helloooo
I have to say my micro-machine is driving me a bit mad but I suppose it would be expected from a 12year old car.
I'm gonna have the headgasket changed just to make sure because there's a little oil residue around the engine block (oil level is within normal values, very clear and I don't get any oil drops in the garage). Head will also be skimmed when replacing.
A thing that is bothering me is that for the second time in one month I have water (cold) dripping on passenger side wheel arch and onto the floor (if like last time it's the window washer water again)
And a new one from today. My car usually runs rather cold (see here) but today it won't go under 75/80 on open road and cold weather. For the first time, (this happened after a quick stop to grab some coffee) when I started the ignition the temperature was 95ºC. Usually when I stop, the fan goes on and it levels at 90ºC (if the stop is quick that's the temperature when I turn the key).
Sorry for the long post, but I'm going to Fiat for a reading/test and I wanted to know wich things are better to replace in Fiat and wich ones can be a DYI (like sensors, engine and gearbox supports, lambda sensors, etc). My mechanic is a capable professional but some things should be observed in Fiat, right?
