CD drive stuck
CD drive stuck
Cheadle, Staffordshire
Hello everyone!
as the title says my cd drive has got stuck. its been fine ever since we've brought it nearly 2 years..but the other day we opened it and it got stuck.. and wont go back into the computer, when you push the button you can hear the motors turning but it wont budge!
any suggestions anyone?
Unbend a paper clip and put it in the little hole in the front and close the tray, get a new one after this, considering the price they ain't worth fixing really.
Liam
Babz said:
it aint a problem with it not working as the PC has 2 drives.. its just its sticking out and just wont go back in :( tried forcing it but dont wanna push so hard it snaps the bay :eek:
well theres one way.....
Liam said:
Seems no one listens to me!
Get the paper clip into the little hole on the front panel and it will slide in or it should.
Liam
if she cant push it in, its jammed either the mechanism or the motor itself
all the little button does is force the motor to opperate (which if its jammed shouldnt work :p)
Bushboy said:
Liam, there is no front panel really.. its one of those HP PCs where the drives are built into the case, i know there is a proper drive in there somewhere but theres no access to it from the outside :mad:
You'll have to take it out from inside the case and replace it with a new drive by the sounds of it. unless you fancy taking it to bits (the drive that is)
