Got the proxy alignedof course
Did you expand to 235 ? or 250 bits ?Got the proxy aligned
Now the android auto stopped working
Edit:
Forgot to change some numbers
Android auto now works.
Just working on the odometer flash
I followed what was in the forum.Did you expand to 235 ? or 250 bits ?
Im asking because i want to do it too...
My first guess would have been not plugged in the back, but then I remember we had to change some numbers in the proxy alignment to get android auto working.Hey Guys!
Maybe someone can help me
I had a 500x from 2016 and I have installed the uconnect 7 with has been produced in 2021.
Everyhting else works except the android auto.
Exactly the usb ports are not working
If someone can help me out it would be so nice because this was the reason why i have changed the uconnect 5 to this one.
The proxy is good, the odometer is not flashing, gps, steering control, etc. Everything else is working. Just usb is not OK.
The icon of it is grey, like it is inactive, but it can charge the phone.
We did this...Did you expand to 235 ? or 250 bits ?
This was above. I had to do this to get it to work.Hey Guys!
this is what I exactly did, but it still not working. Now at least I know the USB is working, because I put back the old uconnect 5 and it is working. But after I put back a the uconnect 7 it is not working again, neither with a pendrive.This was above. I had to do this to get it to work.
"I recently did the same procedure and CarPlay is working. First extended the proxi length to 235 bytes and modified the following bytes as written:
Byte 148= 05 Uconnect 7
Byte 157= 01 CarPlay
Byte 160= 01 Android Auto"
