Technical  Rear view camera retrofit
zisisv
I have a 2015 500x cross. I recently replaced the old radio unit with the newer Uconnect 7 inch. The car does not have a rear view camera from factory. Does it come with the original wiring harness in the trunk lid? I know that I can install an aftermarket kit but I would like to know if I can fit the oem one, with the best possible functionality. Using Multiecuscan I saw an option about rear view camera, so I figured out that the BCM supports it. If there is no harness, would it be possible to run a new one to the BCM and adding the pins to the couplings? I found the couplings into this thread.
Thanks in advance
Model
500x Cross 1.6 mtj
Year
2015
Thanks in advance
I have a 2013 lounge but I ran a new cable and camera for a new radio. It wasn't too bad except for the hatchback. I took out the back seats and most of the side panels and molding. This gave the added benefit of installing heat shielding and sound deadening padding. I did the floor and both sides. I was a lot of work but it was worth it and fun actually.
Hello, sorry to bother you, but could you please provide me with the reference number for the camera connector?
Thanks in advance
I also have a fiat 500x, can I ask you for some information about installing the uconnect 7 screen? I just found some information about doing the retrofit in fiat/abarth 500 but i don't think its is the same process when it comes to the proxy alingment. So it will be very helpful. Thanks!
