SDHXIII
Hello.
You might remember me as the one that had no idea about engines and who couldn't really understand the language of the Haynes Manuals.
I have a problem with my 500 cutting out and then having troubles restarting.
Well I have managed to check and adjust the points and timing. That made a huge difference, the car starts first time and runs smoother and is that much more responsive.
But the car still cuts out.
My next point of call is the carburettor. I have taken the cover off and found that the chamber of fuel where the float lives does have a fair bit of gunge in the bottom. I'm presuming that this should should not be the case and if there is gunge there then there's likely to be gunge elsewhere.
So my question are:
1 - Having taken the cover off, how do I get the rest of the carb off. I can see two obvious bolts but understand that there should be four. Where are the other two please.
2 - What are the key areas I need to check for when cleaning, do I need to pay more attention to certain parts of the carb.
3 - The car had no fuel filter in place when I got it. I will fit one, but where is best? I have seen them before the fuel pump and I have seen them after.
3 - Given the carb has some gunge in, is it likely the pump will too and does this need to be dismantled and cleaned as well.
Answers or other suggestions gratefully received. Please can answers be in very basic terms given my level of ability ?
Many thanks, as always,
Stuart
1969 RHD FIAT 500 (650cc) F
Made in Turin, 1969 ??
Came to the UK, 1992 ??
Full restoration, 2015 ?
? Instagram: FIAT_500f
So my question are:
Stuart
