chaos said:On my 899,when you turn it over, you can hear the fuel pump whirring/humming.....
project-cinqy said:If the starter and bumping doesn't work but the ecu clicks, is the ecu warning light (little spray symbol on the dash) lighting up? If so then the ecu could be dead. The clicking could be it malfunctioning. Take the plug of the ecu and blow any dust out, and wd40 it to be sure then plug it in.
Also check all the earth connections, as a dodgy earth will seriously limit the amount of power the battery releases!
Jon+Em
