As most of you are aware I've recently had a stage 3 head put on my car as my old head decided to blow a hole in itself between cylinders 1 & 2 when the head gasket went in the same place.
I put everything back together as I found it, but replaced all the vacuum hose with silicone stuff and replaced any old looking hose clips and generally cleaned everything in the engine bay.
I also put on a 40mm TB from tricker, Denso iridium plugs and restuded the head front and back and replaced all bolts on the inlet and exhaust manifolds and new gaskets everywhere etc etc, to say the engine looks good is an understatement compared to the oily mess it was before.
So all's well, or so I thought until I tried to start it! First battery was flat from siting for 6 weeks and of course me running an inspection light from the battery for hours on end didn't help.
So even with a melted plug and no compression in cylinders 1 & 2 my car still started and ran very roughly of course before the old head came off, now with new head on it turns but will not start. There's a spark, theres fuel getting through cos I can smell it off the plugs, but nothing.
Could i have got the timing wrong on replacing the belts as I did spend a long time trying to get it right as I couldn't just line everything up before removing the belts as you would do in a normal change. the head I'm sure came back set as it would be at TDC, and its very easy to set TDC when you have no head on an engine cos you can see the pistons, but any ideas would be welcome.
Aaron.
Aaron.
