hi everyone,
can anyone help with a query. Every time i go to put the heating on, all the lights come on. Has anyone experienced this at all. My car is a fiat punto dynamic.
Please help
Just to rul it out:-
I don't know about the Punto ( I have never had one), but do check all of the cars earthing points/wires/blocs. I do not know how the Punto is constructed, so it may have any combination.
A broken earth wire can manifest itself in virtually *any* strange combination of unnconnected electrical appliances, as the postive feed in tries to find its way to earth.
As an example of what a disconnected earthing wire can do:-
On my 1972 Citroen DS, I once mistakenly knocked the left front headlight *earthing* connection off (not the positive feed).
This resulted in when I went to put the headlights on....in me having a very dim left front headlight and sidelight, and the left back indicator on ! Not blinking...but a constant light.
This was with the indicator on he stalk in the "off" position.
For some reason the path the headlight positive feed found to earth itself was through the rear left indicator.
When I found the pulled out earth wire, I plugged it back in, and hey presto everything was normal again.
Once you have experienced it, you always check the earths/earthing points, in order to rule them out.
