Hi there, so I am another proud owner of Fiat Stilo
I have the car around 6 months now and recently, I changed clutch. After that my bonnet started to open when I shutdown engine, or unlock doors. Once it happened when I sat down into the car. Also, .Follow me lights are turning on at the same time. It is not happening allways, it is mostly random.
Should I suspect wire problem - bad ground or is it CAN related problem? What you think? Where should I start cchecking signals? I allready disconnected battery overnight, checked ECU ground, checked and cleaned D4 connector. Thanks!
