Car Battery
Car Battery
B
Bahney
i went to my car this evening only to find the battery flat :( a call out to the rac and it was sorted and is now on charge.
only prob is that i only do short journeys all the time so i not chargeing the battery all the time.
i have just purchased some ice which will arrive on monday now i am assumeing with the power consumption being higher i will proabibly have to charge my battery all the time :(
it is the original battery by the way so i think it is need of a swop, is there any really good high power batterys i can get or are they all pretty much the same?
i want one that will power my car/ice for more then a few months of journeys. cheers guys
Even a big battery will run out eventually if you never charge it fully.
Have you checked the alternator voltage? Should be 13.8v across the battery with the engine running.
Re: Re: Car Battery
how would i do that ? i am guessing i would need some sort of special tool ?
Re: Re: Re: Car Battery
A multimeter
Very useful, usually about £15
Re: Re: Re: Re: Car Battery
Or take it to Kwik-Fit-Up, tell them you think you may need one and you'd like it tested, ask them to show you the reading then feck off and buy your battery elsewhere.
Shabash!
Re: Re: Re: Re: Re: Car Battery
nice1 ozric i will do that, lol
any ideas what the reading should be ? (gwan tom u know you want to answer this)
thanks in advance
Re: Re: Re: Re: Re: Re: Car Battery
Between 13.8v and 14.5v with the engine running. Any less and its not charging properly.
Re: Re: Re: Re: Re: Re: Re: Car Battery
cheers tom you are a star
Re: Re: Re: Re: Re: Re: Re: Re: Car Battery
One thing I like about GM (vauxhall cars) is the fact that parts and even bloody engines can be swapped with little or no sweat. I had a Carlton alternator on my Cavalier, and also with a bigger battery.
Are the alternators for the bigger Fiats better? If so, can I swap for my 100 16v.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Car Battery
are optima batteries any good ? i have hered of these before and supposidly last 3 times longer, anyone had experience with these before ?
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Car Battery
They are, and expensive!!!!!
What you must remeber is that there is a finite limit to how fast you can charge a car battery. If you do it too fast you will damage it.
If your alternator is charging OK, ie 13.8v or more, then there is no point having a bigger one as it will charge at the same rate.
Now if the voltage is ~11-12v when the engine is running but no sound your alternator is furked. If its ~11-12v with sound but ~14v without then you need a bigger alternator. If its ~14v with sound but drops to ~11v with the beat then you need a bigger battery.
C
6K
Carroll
C
J
1
587
Dark Lurker
M
3
285
M
A
4
247
Carroll
C
A
389
A
